I’m trying to browse through all of my tags and read all of the tags named “override” i have in valve tag folders that currently have the state “False” (Every valve has a folder, with common tags such as “override”, “open”, “close” etc).
Currently I am able to navigate down through folders and subfolders using system.tag.browseTags
tags = system.tag.browseTags(parentPath="[SQLTags]AcuteManualFilling/MainProgram", tagPath="*XCV*")
for tag in tags:
c = tag.fullPath
tags1 = system.tag.browseTags(parentPath=(c), tagPath="*Override*")
for tag in tags1:
# print tag.name
a = tag.fullPath
This returns the following (Which is what I want to see)
[u'AcuteManualFilling/MainProgram/XCV857/Override']
[u'AcuteManualFilling/MainProgram/XCV856/Override']
[u'AcuteManualFilling/MainProgram/XCV855/Override']
[u'AcuteManualFilling/MainProgram/XCV854/Override']
[u'AcuteManualFilling/MainProgram/XCV853/Override']
[u'AcuteManualFilling/MainProgram/XCV852/Override']
[u'AcuteManualFilling/MainProgram/XCV859/Override']
[u'AcuteManualFilling/MainProgram/XCV858/Override']
I then use system.tag.read(a).value, which tells me if the tag is True or False.
I use an IF statement and in this I want to append the tag path to a dataSet, to list all of the override tags that are “False”
c = tag.path
if values == False:
#print c
header = ["Valve"]
data = []
data.append(c)
#print data
overrides = system.dataset.toDataSet(header, [data])
However, only one line appends to the dataset (the first tag detected):
Is there a way to populate multiple rows with every override tag path that has been detected as False?
It looks like the data is being reinitialized to empty inside of your loop. The data and header initialization should be placed outside of the loop. Try something like this instead (not tested).
header = ['Valve']
data = []
for tag in tags:
value = system.tag.read(tag.path).value
if value == False:
c = tag.path
#print c
data.append(c)
#print data
Hey Nick,
Thanks for the response. I am getting the following output:
[SQLTags]AcuteManualFilling/MainProgram/XCV857/Override
File “”, line 20, in
IndexError: Row 0 doesn’t have the same number of columns as header list.
So it still seems to be only catching the first “Override” instance it sees.
As for the indexError. Does the number of rows in a dataset need to be specified? Does it not just auto append each “Override” valve as a new row (Atleast that’s what I want to happen!)
You’re both halfway right. You do need to initialize data outside the loop - however, you also want to append each row as it’s own row object, due to the way system.dataset.toDataSet works; you need to construct a “two dimensional” array, which in Python is represented as a list of lists:
[1], # row1 - should be as many elements as there will be columns in the output
[2], # row2 - must match row1's length
[3] # row3
Leave data as @nick.schuetz had it - initialize it as an empty list before starting the loop. Then change the line after header = ["Valve"] to data.append([c]) - data will be your list of rows, and then you will append each row to it, as a unique list.
Then drop the square brackets in the call to system.dataset.toDataSet, since you already have a 2d array/list.
Thanks @paul-griffith!
It worked a charm and thanks for the informative explanation
