Hello,
I'm seeking some help.
I'm having issues browsing the tags for an AB Compactlogix 5380 PLC , 5069-L320ER. firmware 28.011.
Currently my set up is running the Ignition gateway on my local plc, and the PLC is hooked up directly to my PC.
computer static IP: 192.168.5.200
PLC static IP: 192.168.5.1
Using AB Logix Driver for the device connection, getting "Connected".
Also able to ping PLC and get online.
these are the logs I'm getting when trying to browse the tags, currently none are showing up.
Browse failed: status=0x01 [connection failure] , additional=[0x0312]
com.digitalpetri.enip.cip.CipResponseException: status=0x01 [connection failure] , additional=[0x0312]
at com.digitalpetri.enip.cip.services.GetAttributeListService.decodeResponse(GetAttributeListService.java:45)
at com.digitalpetri.enip.cip.services.GetAttributeListService.decodeResponse(GetAttributeListService.java:12)
at com.digitalpetri.enip.cip.services.UnconnectedSendService.decodeResponse(UnconnectedSendService.java:122)
at com.digitalpetri.enip.cip.CipClient.lambda$invoke$2(CipClient.java:124)
at java.base/java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.complete(Unknown Source)
at com.digitalpetri.enip.cip.CipClient.lambda$sendUnconnectedData$8(CipClient.java:222)
at com.digitalpetri.enip.EtherNetIpClient$PendingRequest.lambda$new$0(EtherNetIpClient.java:412)
at com.digitalpetri.enip.EtherNetIpClient.onChannelRead(EtherNetIpClient.java:220)
at com.digitalpetri.enip.EtherNetIpClient.access$900(EtherNetIpClient.java:50)
at com.digitalpetri.enip.EtherNetIpClient$EtherNetIpClientHandler.lambda$channelRead0$0(EtherNetIpClient.java:346)
thanks in advance for any help or suggestions.
