@paul-griffith Paul, this a continuation of our discussion. Although 8.0.10-rc1 helped, there is an underlying problem with binding to an array of datasets. Whenever I bind to an array of datasets to pass data to a param in an embedded view, I get this error and for about 2 seconds browsercore spins up to about 100% of cpu. This error occurs in red on my console.
java.lang.ClassNotFoundException: com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Unknown Source)
at java.base/java.io.ObjectInputStream.resolveClass(Unknown Source)
at java.base/java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject0(Unknown Source)
at java.base/java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at java.base/java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject(Unknown Source)
at java.base/java.util.HashMap.readObject(Unknown Source)
at java.base/java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readArray(Unknown Source)
at com.inductiveautomation.ignition.common.Base64.decodeToObject(Base64.java:912)
at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.onBindingPreviewValue(JavaJsBridge.java:343)
at jdk.internal.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
at com.teamdev.jxbrowser.chromium.JSContext.a(SourceFile:1640)
at com.teamdev.jxbrowser.chromium.JSContext$a.onMessageReceived(SourceFile:713)
at com.teamdev.jxbrowser.chromium.internal.ipc.q.a(SourceFile:1085)
at com.teamdev.jxbrowser.chromium.internal.ipc.r.run(SourceFile:69)
at com.teamdev.jxbrowser.chromium.internal.t.run(SourceFile:79)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
