[BUG-1050] 8.1 Installer Issue
Hi all,
I am new to ignition and have been working with 8.0.16. I am upgrading to 8.1 but am having issues with the installer. This is a Windows 10 Professional system.
The first screen looks washed out but it might be ok…
The Location seems ok, so I pressed next…
This is where I bailed out…
I was taught not to agree with something I cannot read!
I had a similar problem with the designer and client launcher when I originally installed Ignition.
This thread solved that issue if this helps,… Ingnition Designer Launcher - Blank window - #9 by jcoffman
Thanks, Steven
@jcoffman maybe we should disable hardware rendering in the installers by default?
hmm @Kevin.Herron i can look into that.
In the meantime you can run the installer in Text Mode or include the -Dprism.order=sw arg when running the installer
@jcoffman,
That made that quick and easy. I am back up and looks like all is well.
If you need me to test on this I will be happy to help out.
Thanks, Steven
