in a flex-layout view I have two parameters:
- input parameter, called “appTypeId”
- output parameter, called “navTreeId”
The output parameter is bound to an expression structure and a scripting transform.
if I close and re-open the view, the output parameter does no longer appear. If I select another component inside the view (a drop-down component or the root, for example) and I come back to the view, the property is present again.
Am I wrong in doing something?
Thank you.
P.S.: maybe it is the same issue as: [Bug-10710] Session Custom Properties Dissapearing
This looks like this is a separate issue than the forum post you linked. Poking around at this showed the cause a lot more clearly. I’ll update our internal ticket. Thanks for bringing this up! Also, this looks like with will happen with any parameters that are bound. Clicking on another component and clicking back is the workaround we found as well. So you aren’t doing anything wrong, this is something wrong on our end.
Thank you for your reply.
This issue should be fixed in the latest build. Please let us know if you continue to see this behavior after upgrading.
