[bug-1084]System.tag.browse null pointer exception
I have a popup that utilizes system.tag.browse('') to return a list of tag providers. This worked fine in 8.0, but seemingly with an upgrade to 8.1, this began giving me a null pointer exception:
  File "<event:visionWindowOpened>", line 7, in <module>
	at com.inductiveautomation.ignition.client.script.ClientTagUtilities.browseImpl(ClientTagUtilities.java:126)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.browse(AbstractTagUtilities.java:345)
	at jdk.internal.reflect.GeneratedMethodAccessor296.invoke(Unknown Source)
java.lang.NullPointerException: java.lang.NullPointerException
	at org.python.core.Py.JavaError(Py.java:552)
	at com.inductiveautomation.ignition.client.script.ClientTagUtilities.browseImpl(ClientTagUtilities.java:140)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:523)
	at org.python.core.PyObject.__call__(PyObject.java:497)
	at org.python.core.PyObject.__call__(PyObject.java:501)
	at org.python.pycode._pyx363.f$0(<event:visionWindowOpened>:8)
	at org.python.pycode._pyx363.call_function(<event:visionWindowOpened>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:781)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:206)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:297)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy50.visionWindowOpened(Unknown Source)
	at com.inductiveautomation.factorypmi.application.FPMIWindow.fireVisionWindowOpened(FPMIWindow.java:711)
	at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:545)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:188)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$openWindowImpl$5(NavUtilities.java:393)
	at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:808)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:336)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:326)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
	at org.python.core.PyObject.__call__(PyObject.java:480)
	at org.python.core.PyObject.__call__(PyObject.java:484)
	at org.python.pycode._pyx362.f$0(<event:actionPerformed>:7)
	at org.python.pycode._pyx362.call_function(<event:actionPerformed>)
	at com.sun.proxy.$Proxy46.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.NullPointerException
	... 79 more
Ignition v8.1.0 (b2020110211)
Java: Azul Systems, Inc. 11.0.7
Note that I don’t get the error when providing a tag provider as the path, e.g. system.tag.browse('[default]'). Also note that this function seems to work fine when executed in the designer. It’s only in the Vision client that I get the exception. Possible 8.1 bug, or is this just not a supported use case for system.tag.browse?
No issue using it here. Try deleting the client’s cache and see if that helps.
No luck unfortunately. Cleared my client cache and java cache for good measure, but no change in behavior.
Do you have a default tag provider set on your project (I can’t imagine you don’t, but :man_shrugging:)?
Are there any errors being logged on the gateway when this browse fails?
I actually didn’t. My project has multiple tag providers of equal significance, so I assumed was fine. Seems like setting that resolved the issue though!
More broadly, is it poor practice to not have a default tag provider configured?
I definitely wouldn’t call it bad practice; just unusual. Clearly, it exposed an invalid assumption on our part. I’ll file a ticket to resolve in some future version.
