I have two Perspective views open, one called Title and one Tank. I am looking at Tile and select the tab for tank and the following error pops up:
ExecutionException: java.lang.RuntimeException: Could not save View ‘Title’. Expected string, found JSUndefined
caused by RuntimeException: Could not save View ‘Title’. Expected string, found JSUndefined
Ignition v8.0.0-beta0 (b2018111002)
Java: Azul Systems, Inc. 11.0.1
I have two views open in the designer. It happens when I go from one to the other. I did notice that if I just leave a view open in the designer this pops up in the output console:
We’ve noticed this behavior quite often when Designer sessions have been open for long durations, during which they’ve (temporarily) lost connection to the Gateway one or more times. To my recollection, we haven’t lost any data, despite the warning. Consider Saving once more and then closing your Designer and re-launching it.
Until we reach launch, the recommended mantra is “save often”, just-in-case.
If the Save/Relaunch recommendation doesn’t work, please let us know (including if you do believe you’ve lost any saved progress).
