When using a breakpoint view, It seems that once I select the “small” or “large” component, that is bolded in the tree, and though I can click on the other one and see it’s properties or the properties of objects on it, I can’t see it- the originally selected “size” is all I can bold in the tree. I always have to close the view and re-open it. Is there another way to switch between these?
Modifying the actual dimensions of the Breakpoint container by dragging the edges until they would be within the specified dimensions of the alternate breakpoint should transition you from one layout of the Breakpoint to the next, but there is already an open internal ticket to make this easier to do as well as make it more clear which layout (breakpoint) you are currently in.
