[BUG-11624] Error on Creating New JDBC Driver
Attempted to add a new JDBC driver to connect to a third-party historian and ran into an error on create:
“Error updating JDBC Driver “NewDriver”.
Executing INSERT INTO JDBCDRIVERS (JDBCDRIVERS_ID, Name, Description, DefaultTranslatorId, Classname, DefaultProps) VALUES (?, ?, ?, ?, ?, ?) for [JDBCDriverRecord 2 NewRecord Dirty0]
See log for details.”
I can post the log details as well if that helps.
I tried a variety of different empty vs filled fields in the add form, and I was able to get a new driver to be created at one point successfully, but of course in trying to replicate what I did, I deleted it and tried again, only to have it fail to create on the second try, so no idea why it worked once.
I ended up just re-purposing one of the other drivers that I was not using in the meantime and was able to modify that and get that connection working.
Version: 8.0.0-beta0 (b2018111302)
Chrome Version 70.0.3538.77
The rest of the details from the log would be helpful.
Here you go:
simpleorm.utils.SException$Jdbc: Executing INSERT INTO JDBCDRIVERS (JDBCDRIVERS_ID, Name, Description, DefaultTranslatorId, Classname, DefaultProps) VALUES (?, ?, ?, ?, ?, ?) for [JDBCDriverRecord 2 NewRecord Dirty0]
at simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:434)
at simpleorm.sessionjdbc.SSessionJdbcHelper.flush(SSessionJdbcHelper.java:400)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:459)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:443)
at simpleorm.sessionjdbc.SSessionJdbc.commitAndDetachDataSet(SSessionJdbc.java:382)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.commitRecords(AbstractRecordEditPanel.java:206)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.onSubmit(AbstractRecordEditPanel.java:158)
at com.inductiveautomation.ignition.gateway.web.pages.config.databases.JdbcDriverEditPage.onSubmit(JdbcDriverEditPage.java:78)
at com.inductiveautomation.ignition.gateway.web.components.AbstractRecordEditPanel.onSubmit(AbstractRecordEditPanel.java:125)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm$1.onSubmitInternal(RecordEditForm.java:94)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:67)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1248)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1242)
at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274)
at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1241)
at org.apache.wicket.markup.html.form.Form.process(Form.java:923)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:769)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:702)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:240)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:226)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at com.inductiveautomation.ignition.gateway.bootstrap.GatewayFilter.doFilter(GatewayFilter.java:74)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1629)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:533)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:289)
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:149)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
Caused by: java.sql.SQLException: [SQLITE_CONSTRAINT] Abort due to constraint violation (UNIQUE constraint failed: JDBCDRIVERS.JDBCDRIVERS_ID)
at org.sqlite.core.DB.newSQLException(DB.java:890)
at org.sqlite.core.DB.newSQLException(DB.java:901)
at org.sqlite.core.DB.execute(DB.java:810)
at org.sqlite.core.DB.executeUpdate(DB.java:847)
at org.sqlite.jdbc3.JDBC3PreparedStatement.executeUpdate(JDBC3PreparedStatement.java:86)
at com.inductiveautomation.ignition.gateway.localdb.DelegatingDataSource$DelegatingConnection$DelegatingPreparedStatement.executeUpdate(DelegatingDataSource.java:585)
at simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:432)
This is a known issue - the fix will go into one of the next nightlies.
This should be fixed as of the 11/20 build.
Having trouble creating a JDBC Driver. Same issue reported earlier. Using the latest nightly build. Please see below.
simpleorm.utils.SException$Jdbc: Executing INSERT INTO JDBCDRIVERS (JDBCDRIVERS_ID, Name, Description, DefaultTranslatorId, Classname, JarFile, URLFormat, DefaultProps) VALUES (?, ?, ?, ?, ?, ?, ?, ?) for [JDBCDriverRecord 4 NewRecord Dirty0]
… 67 common frames omitted
