Vision Client Tag Export (both json and xml) outputs a blank file.
Using standard right click and select export on tag to be exported.
Is there a fix for this? I’m not seeing any other posts for this issue, maybe I’m using the wrong right click button…
This is an issue we are aware of. Importing and Exporting Vision Client tags do not currently work.
Garth
This issue was fixed in the build that was uploaded today (2/4).
Please let us know if you continue to see this behavior after upgrading.
