[BUG-12252, 12253] Unable to save IdP
Version - 8.0.0-beta0 (b2019010702)
What was done -
Attempting to setup a new OpenID identify provider to Auth against Microsoft (o365/Azure) for our private tenant.
  1. Configured Azure with a new App Registration clientID/secret/config URLs etc…
  2. Setup the Provider Name, etc…
  3. Loaded the OpenID config via the metadata document by clicking import
  4. Added ClientID/Secret
  5. Clicked Save
  6. ERROR Could not save IdP
Can you check if there are any errors in the gateway logs?
Ahhh ha… yes, did not appear in the logs, but found in the wrapper.
I striped out the sensitive information, as all the auth config was printed to the wrapper including secrets (prob should be fixed too). If you need more info, PM me.
INFO   | jvm 1    | 2019/01/07 09:45:03 | com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerException: Problem adding new IdP config
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl.addConfig(IdpAdapterManagerImpl.java:365)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterConfigRoutes.createIdpAdapter(IdpAdapterConfigRoutes.java:78)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:244)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:49)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.DataServlet.service(DataServlet.java:87)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.Server.handle(Server.java:530)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:289)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:149)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2019/01/07 09:45:03 | Caused by: simpleorm.utils.SException$Validation: Param too long (>-1) for field [F IdpAdapterRecord.CONFIG] and value {"name":".....
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.validation.SValidatorMaxLength.onValidate(SValidatorMaxLength.java:32)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.SFieldMeta.doValidate(SFieldMeta.java:294)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.SRecordInstance.doValidateField(SRecordInstance.java:940)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.SRecordInstance.setObject(SRecordInstance.java:291)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.SRecordInstance.setObject(SRecordInstance.java:248)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at simpleorm.dataset.SRecordInstance.setString(SRecordInstance.java:424)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterRecord.setConfig(IdpAdapterRecord.java:40)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.auth.idp.PersistentRecordIdpAdapterConfigService.add(PersistentRecordIdpAdapterConfigService.java:193)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl.addConfig(IdpAdapterManagerImpl.java:363)
INFO   | jvm 1    | 2019/01/07 09:45:03 | 	... 41 common frames omitted
Thank you for reporting this. I have isolated the root cause and will issue a fix shortly.
You are totally correct in that sensitive information from the IdP config such as the client secret should not print plaintext to the logs. I will also fix that issue.
These issues have been fixed in the build that was uploaded today (2/4).
Please let us know if you continue to see this behavior after upgrading.
