after upgrading to 1/14/19 nightly build, gauge needles seem to get stuck in the gauge component’s initial 0* position after a page refresh, or Save and Publish, until a value change. After the tag changes, the gauges behave normally.
In the screenshot, Line 1 and Line 3 have changed values after the page reload.
Prior beta (12/18/18) did not have this issue.
I’m guessing this is related to a fix I just made for a different issue with tag bindings - see the changelog:
I’ll see if there’s a better way we can fix this.
@hunterdg
I wasn’t able to replicate this behavior on the latest build. Are you still encountering this issue?
Just updated to latest build. Same issue.
We’ve had a few people try to reproduce this internally - would it be possible to send a project export or gateway backup in to us so we can try to mock this up?
Thanks - it looks like the fix I initially put in for direct tag bindings didn’t make it to indirect tag bindings. A new fix is up for review - should make it into a nightly next week. Hopefully that resolves your issue.
Thank YOU very much, will report back.
Change will go into the next nightly - should hopefully fix your issue.
This issue was fixed in the build that was uploaded today (3/1). Please let us know if you continue to see this behavior after upgrading.
