in the beta build b2019010702, I found an error in using the binding script of a component.
As an example, in the binding of a label component I use the following script:
I call the class “Label” written in the module “menu” (shared>persp>model>system>menu the complete path of the script) and I get the expected object: “<menu.Label instance at 0xa>”.
Then, if I make a modification in the “Label” class, after the commit I get the following error:
“Traceback (most recent call last):
File “”, line 4, in transform
AttributeError: ‘com.inductiveautomation.ignition.common.script.Scr’ object has no attribute ‘persp’”
It seems like the custom package is no longer visible.
In order to run again the script, I have to close and re-open the designer session.
In the earlier beta versions I tested, this error was not present.
