In Tag Editor, if you change details of an existing tag (add or delete details), press Apply or OK, those (new) details don’t get changed. If you change anything else on the tag editor, they will get saved - so only messes up essentially if you are modifying comments of your existing tags. Designer B2019021302
Hi Kingw
I believe when you are taking about details you mean the Documentation property under the Meta Data Properties in the tag editor .
I was able to see the same issue when I tried to add some text and selected on Ok or Apply button the text was not retained will write a ticket for it and keep you updated.
This issue was fixed in the build that was uploaded today (3/7). Please let us know if you continue to see this behavior after upgrading.
