Good morning,
the “system.device” library does not appear inside the perspective scope.
I get the following error:
“AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘device’”.
Thank you.
Good morning,
Thank you.
This actually seems to be a bug instead of a feature - that library should be visible in the Designer for both Perspective and Vision projects, but it doesn’t show for either. I’ve opened an internal ticket for the issue.
Thank you.
In the current build b2019031702 the library has been included again.
