If a template is built using other templates (templates within templates). These templates will render on a screen, and within a template repeater, however there is an issue with this template inception as it relates to the Template Canvas.
Below is the error I am seeing in the console.
Is this possibly paired with Bug-12703?
Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.components.template.TemplateHolder.loadTemplate(TemplateHolder.java:214)
at com.inductiveautomation.factorypmi.application.components.template.TemplateHolder.initTemplate(TemplateHolder.java:507)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor$TemplateHolderVisitor.visit(ComponentVisitor.java:220)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor.walk(ComponentVisitor.java:90)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor.walk(ComponentVisitor.java:68)
at com.inductiveautomation.factorypmi.application.FPMIWindow.initializeUIRoot(FPMIWindow.java:322)
at com.inductiveautomation.factorypmi.application.components.template.VisionTemplate.initialize(VisionTemplate.java:168)
at com.inductiveautomation.factorypmi.application.components.TemplateCanvas._finishBuilding(TemplateCanvas.java:275)
at com.inductiveautomation.factorypmi.application.components.TemplateCanvas$TemplateLoader.done(TemplateCanvas.java:616)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
