[Bug-12932]Leased Tag Groups not scanned at Leased rate
My default tag group is a leased mode, with a rate of 5,000 and a leased/driven rate of 1000. Having added a PLC “seconds” tag, I can see that it is only updating every 5 seconds regardless of whether it’s being viewed in the designer or a perspective session.
I haven’t been able to find any record of this being a bug on the forums, and I’d expect that others would have discovered it before now, but I’ve been over the settings a few times and can’t find anything that might be. I created a new tag group; as soon as I set it to leased, it displays the same symptoms.
My default tag group is set up as follows:
Data Mode: Subscribed
Read after write: true
Optimistic writes: true
Optimistic write timeout: 10,000
I’ve messed with all of those settings to no avail.
This looks to be an issue and I have created an internal ticket for it. It was working at one point, so I am guessing there were changes that caused something to break.
Garth
This issue should be fixed in the newest build. Please let us know if you continue to see this behavior after upgrading.
