we can’t seem to import the .json file after we’ve exported the config. We get this error:
Did you attempt to import the Launcher Config, or an Application Config? If the latter, how did you obtain the Application Config in the first place? Nevermind, I was able to replicate the issue.
This issue was fixed in the build that was uploaded on 3/16. Please let us know if you continue to see this behavior after upgrading.
Thanks it seems to be working now!
If I configure the vision-client-launcher.json to lock the configuration (lock.configuration": true, it doesn’t seem to lock the settings out. Will there be a way to import settings to “lock” out the settings eventually?
