[BUG-13211] Windows and Templates turned into folders
I have encounted a problem where when i open the project in the design launcher most of my windows and templates are now gone and replaced by folders with the same name. In the gateway diagnostic logs i have about 15 notifications every 10 seconds pushing this message(This is just for one of the windows/templates):
com.inductiveautomation.ignition.common.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:226)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:927)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:865)
at com.inductiveautomation.ignition.gateway.project.ProjectFileTree$ProjectFileVisitor.createResourceNode(ProjectFileTree.java:485)
at com.inductiveautomation.ignition.gateway.project.ProjectFileTree$ProjectFileVisitor.preVisitDirectory(ProjectFileTree.java:421)
at com.inductiveautomation.ignition.gateway.project.ProjectFileTree$ProjectFileVisitor.preVisitDirectory(ProjectFileTree.java:347)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.lambda$create$12(ProjectFileTree.java:271)
at java.base/java.util.Spliterators$ArraySpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.project.ProjectFileTree.create(ProjectFileTree.java:269)
at com.inductiveautomation.ignition.gateway.project.ProjectFileWatcher.scanProjectsDir(ProjectFileWatcher.java:65)
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.inductiveautomation.ignition.common.gson.stream.JsonReader.beginObject(JsonReader.java:385)
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:215)
The schedual backup also stopped working so i was hoping anyone maybe have a solution to this problem as atm, alot of work is gone…
For some unknown reason the ā€œreferance.jsonā€ got cleared on some components,
Solved the issue by going into the ā€œreference.jsonā€ document under each component at
C:\Program Files\Inductive Automation\data\projects\XXXXXX\com.inductiveautomation.vision
and adding a script based on the ā€œreference.jsonā€ file on the components that were working.
Thankfully not much work was lost!
This ā€˜resources getting turned into folders’ bug is an issue high on our priority list, that we’re hoping to have fixed in 8.0.6.
This issue was fixed in the 8.0.6 nightly build that was uploaded today (10/21).
