[BUG - 13214]Unable to delete tag script after applying changes in memory Tag
As the title suggests. I can’t delete a custom property I created for a handful of UDT tag elements
Hi Joshdandy
Could you send me an example or a gateway backup that you are seeing the issue on so that it will easier to replicate?.
Thanks,
Anthony
Sorry I can’t send a gateway backup…
This also occurs with tag scripts. I cant delete tag scripts. They look like they are deleted when I press apply, but browsing back to the tag, the tag script is present again. The only way around it has been to delete the tag and recreate it.
Hi Joshdandy
I was able to duplicate the issue with the tag scripts not deleting the scripts. It seems to happen when you try and delete a script you added to the Tag Events script. It is not delete even after you commit the change by applying it. I will write an internal ticket to keep track of the issue.
Anthony
This issue was fixed in the build uploaded today (4/10).
Normally we have the nightly builds accessible via https://inductiveautomation.com/downloads/ignition, but in the meantime you can find it via this post:
8.0.1 Nightlies - Temporary Place to Download the Latest Builds
Let us know if you have any issues.
