When a Text Field background color is transparent it will turn white when clicked. Then if you click another text field the first text field will show some garbage in the background.
We have an open issue for this that is affecting multiple components. The garbage you are seeing is likely something on your desktop showing through the Vision Client application. We appreciate your patience as we work through this issue.
Garth
