SFC Enclosing chart not working.
Steps to reproduce:
Create simple chart with only the begin and end called ChartA.
Create another chart called ChartB with 3 elements, begin, the Enclosing chart (pointed to ChartA) and end.
When ChartB starts, it is immediately aborted with the following error reported on the GW:
com.inductiveautomation.ignition.common.project.ProjectNotFoundException: project not found: project not found: run-always-charts
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.getProject(BaseProjectManager.java:149)
at com.inductiveautomation.ignition.gateway.project.ProjectManagerBase.getProject(ProjectManagerBase.java:228)
at com.inductiveautomation.sfc.ChartManager.startChart(ChartManager.java:602)
at com.inductiveautomation.sfc.elements.steps.enclosing.EnclosingStep.activateStep(EnclosingStep.java:113)
at com.inductiveautomation.sfc.elements.StepContainer.onActivateRequested(StepContainer.java:142)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:35)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:8)
at com.inductiveautomation.sfc.fsm.StateContext.lambda$handleEvent$0(StateContext.java:49)
at com.inductiveautomation.sfc.api.ExecutionQueue$ThrowableCatchingRunnable.run(ExecutionQueue.java:146)
at com.inductiveautomation.sfc.api.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:120)
