[BUG-13535] Screens lock up client and designer after upgrade to Ignition 8
Hey all,
I am testing Ignition 8 with my existing project and I have successfully imported a gateway backup and for the most part everything is happy. There are a few screens though that if I open them up in either the client or the designer they just completely freeze the client and designer application. I can’t even close them with task manager! How would I go about figuring out the issue with these screens? I think a couple of them have some Sepasoft OEE components on them, could that be the culprit?
Maybe; these modules aren't available for Ignition 8 yet.
I don't think that should lock up the client or designer though...
I did a little more testing and all windows with the OEE components either don’t open with an error or just lock up the client/designer so I think that’s the common denominator. I’ll scrub that stuff out of my Ignition 7.9 project and try it again and see what happens.
I also have a couple of screens that don’t have OEE components on them but fail to open with a serialization error. Seems fairly cryptic to me. Just tables and bar charts on them for the most part. How do I figure out what component is causing this issue?
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element "</o>"
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:977)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:938)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:909)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:359)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:302)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:276)
	at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:482)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:196)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:188)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$1.run(NavUtilities.java:207)
	at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:810)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapWindow(NavUtilities.java:205)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:114)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:101)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.swapTo(NavUtilitiesDispatcher.java:67)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:473)
	at org.python.core.PyObject.__call__(PyObject.java:480)
	at org.python.core.PyObject.__call__(PyObject.java:484)
	at org.python.pycode._pyx39.f$0(<event:actionPerformed>:7)
	at org.python.pycode._pyx39.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:686)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:642)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:182)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:271)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy49.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.0.0 (b2019040718)
Java: Azul Systems, Inc. 11.0.2
Would you be able to upload a backup or project export for us to test with?
Sure, do you want a backup from the original 7.9 gateway or the 8.0 gateway?
Hmm, I suppose it doesn’t matter which. I’ll PM you a link to upload to. Make sure to let me know the name/path to a couple windows that are broken.
I uploaded a 7.9 gateway, in case you want to look at the windows in 7.9 too. There is also a text file with paths to the troublesome windows. Thanks Kevin!
Thanks, I can reproduce this. We’ll try to get it fixed in 8.0.1.
i’m running in to the same issue on a few of my windows. Looking forward to the update!
thanks!
Yes, this issue will be fixed in 8.0.1.
The 8.0.1RC is available at https://inductiveautomation.com/downloads/ignition
