We’re using the EAM to send projects from a dev gateway to other gateways in a scale out architecture. The source project inherits from a global project. After the task completes the destination project has the resources as if they were overridden.
Just to clarify - what you’re saying is sending a project also sends all resources that project inherits as well? And then on the other side all those resources get loaded as if they belong to the project that was sent?
Yes. That sounds accurate.
Ok thanks, we’ll get this fixed.
This issue was fixed in the 8.0.3 nightly build that was uploaded on 6/24.
This issue still exists in 8.0.3 stable.
