Ignition 8.0.2 snapshot 2019-05-13
when I try to create a client tag in designer, I have the following erroe and no tag is created.
18:33:35.425 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.tags.tree.nodes.VisionProjectTagProviderNode - Error creating tag
java.lang.ClassCastException: class com.inductiveautomation.ignition.client.icons.InteractiveVectorIcon cannot be cast to class javax.swing.ImageIcon (com.inductiveautomation.ignition.client.icons.InteractiveVectorIcon is in unnamed module of loader java.net.URLClassLoader @1b2458c8; javax.swing.ImageIcon is in module java.desktop of loader 'bootstrap')
at com.inductiveautomation.ignition.designer.sqltags.config.ui.CategorySelector$Renderer.getListCellRendererComponent(CategorySelector.java:113)
at java.desktop/javax.swing.plaf.basic.BasicListUI.updateLayoutState(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicListUI.maybeUpdateLayoutState(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicListUI$Handler.valueChanged(Unknown Source)
at java.desktop/javax.swing.DefaultListSelectionModel.fireValueChanged(Unknown Source)
at java.desktop/javax.swing.DefaultListSelectionModel.changeSelection(Unknown Source)
at java.desktop/javax.swing.DefaultListSelectionModel.setSelectionInterval(Unknown Source)
at java.desktop/javax.swing.JList.setSelectedIndex(Unknown Source)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.CategorySelector.setCategories(CategorySelector.java:59)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel.refreshCategories(TagObjectEditorPanel.java:205)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel.loadEditWorkspaceFor(TagObjectEditorPanel.java:200)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel.setEditObjects(TagObjectEditorPanel.java:144)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditor.editTags(TagObjectEditor.java:163)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditor.addTag(TagObjectEditor.java:237)
at com.inductiveautomation.ignition.designer.tags.tree.nodes.VisionProjectTagProviderNode.createTag(VisionProjectTagProviderNode.java:65)
at com.inductiveautomation.ignition.designer.tags.tree.TagBrowserPanel$NewTagAction.actionPerformed(TagBrowserPanel.java:1208)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
