On the Gateway Webpage the Status/System/Gateway Scripts Status page is not loading. After clicking to view the page, the Tab Bar will flash on screen for a split second and then the screen will be blank. There is a similar item number that was solved a while ago and might be good reference [BUG-12800].
Browser: Google Chrome
Ignition Version Number: 8.0.2- b20190516
OS: Windows 10 Pro and Windows Server 2016 Datacenter
OS of Gateway Location: Windows Server 2016 Datacenter
Can you check the browser console and gateway logs to see if any errors are thrown when the page fails to load?
I can’t reproduce out of a development environment.
We have this problem too,and have for a long time - all browsers (ie, edge, chrome) has it and it has persisted since at least 8.01 through 8.06
Here’s a dump from chrome - I do not know if it is useful
sys.gateway-scripts?4:1 [DOM] Found 2 elements with non-unique id #timer-panel_pagination_page_input: (More info: https://goo.gl/9p2vKq) <input type="text" pattern="[1-9][0-9]*" id="timer-panel_pagination_page_input" value="1"> <input type="text" pattern="[1-9][0-9]*" id="timer-panel_pagination_page_input" value="1">
DevTools failed to parse SourceMap: http://i8server:8088/web/status/twotiermenu.js.map
DevTools failed to parse SourceMap: http://i8server:8088/web/status/gateway_scripts.js.map
DevTools failed to parse SourceMap: http://i8server:8088/web/status/GatewayBreadcrumb.js.map
DevTools failed to parse SourceMap: http://i8server:8088/web/status/trialbar.js.map
react-dom.js:117 Invariant Violation: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
at pb (http://i8server:8088/res/sys/js/react-dom.js:12:454)
at n (http://i8server:8088/res/sys/js/react-dom.js:13:221)
at wc (http://i8server:8088/res/sys/js/react-dom.js:61:140)
at http://i8server:8088/res/sys/js/react-dom.js:79:83
at N (http://i8server:8088/res/sys/js/react-dom.js:90:3)
at hi (http://i8server:8088/res/sys/js/react-dom.js:105:408)
at Qg (http://i8server:8088/res/sys/js/react-dom.js:144:217)
at Rg (http://i8server:8088/res/sys/js/react-dom.js:145:76)
at Sc (http://i8server:8088/res/sys/js/react-dom.js:158:109)
at Z (http://i8server:8088/res/sys/js/react-dom.js:156:492)
Bg @ react-dom.js:117
c.callback @ react-dom.js:126
Ag @ react-dom.js:116
zg @ react-dom.js:116
qi @ react-dom.js:131
ui @ react-dom.js:133
(anonymous) @ react-dom.js:158
unstable_runWithPriority @ react.js:27
Vc @ react-dom.js:158
Sc @ react-dom.js:158
Z @ react-dom.js:156
Kc @ react-dom.js:155
ya @ react-dom.js:153
enqueueSetState @ react-dom.js:202
t.setState @ react.js:20
u.onStateChange @ VM2549:14
m @ VM2549:14
eval @ VM2549:1
dispatch @ VM2549:14
eval @ VM2549:14
Promise.then (async)
eval @ VM2549:14
eval @ VM2549:1
value @ IgnitionLib-ver-529E74C3F1794104A22D05E8BE29EF08.js:1
setTimeout (async)
eval @ VM2549:14
eval @ VM2549:14
eval @ VM2549:1
(anonymous) @ IgnitionLib-ver-529E74C3F1794104A22D05E8BE29EF08.js:1
F @ IgnitionLib-ver-529E74C3F1794104A22D05E8BE29EF08.js:1
value @ VM2549:14
value @ VM2549:14
Pd @ react-dom.js:69
qg @ react-dom.js:92
hi @ react-dom.js:104
Qg @ react-dom.js:144
Rg @ react-dom.js:145
bh @ react-dom.js:160
xe @ react-dom.js:160
nb.render @ react-dom.js:215
(anonymous) @ react-dom.js:164
$g @ react-dom.js:159
Wc @ react-dom.js:164
render @ react-dom.js:217
cb @ sys.gateway-scripts?4:76
fire @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:2538
fireWith @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:2649
done @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:7038
(anonymous) @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:7327
load (async)
send @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:7344
ajax @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:6957
jQuery.<computed> @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:7077
getScript @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:7065
(anonymous) @ sys.gateway-scripts?4:76
dispatch @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:3782
elemData.handle @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:3632
load (async)
add @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:3671
(anonymous) @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:3598
each @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:269
each @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:90
on @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:3597
on @ jquery-ver-C2E3D53624F901F3F15AE4D03B098EEF.js:4064
(anonymous) @ foundation.min.js:1
VM2549:14 Error fetching script diagnostics: Invariant Violation: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
We were never able to reproduce internally, but I believe some changes were made to how these pages load React components for 8.0.14/8.0.15. I’ll re-open the internal ticket, but it may end up being resolved by those other changes.
I’ve personally noticed this has been much better since about 8.0.10, for me at least. Not sure if it has to do with a script I’ve changed, or if it was gateway updates.
I noticed it seemed to be happening for me when I was running long scripts in a shared thread.
Noticed that happening since 8.0.10. Did not look for it before.
So Gateway Scripts->Timer Script with Fixed Rate and Dedicated Thread
If the script did not finish in desired Delay Gateway Scripts Status Page not loading, disappearing.
In 7.9 If the script did not finish there is an exclamation mark with Slow
In order to make Gateway Scripts Status Page be visible again Delay value must be bigger than script duration.
Seeing the same error here. Mine is on fixed delay but tried it at 10K and 20K ms and still had same issue. Weird thing tho, when I changed it to 20K ms and saved it the page was able to load and showing it never run. But once it did run the page started showing the error again…
