[BUG-13990] Ignition 8.0.2-rc1 - udt instance are very long to create
I try to generate udt definition and instances with the new json format.
Udt import is fine, but when I import the file to create udt instances, it’s very long to create only 6 instances ?
when I create an instance with the designer the gateway is disconnected and it take a very long time…
ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
	caused by GatewayException: Read timed out
	caused by SocketTimeoutException: Read timed out
Ignition v8.0.2-rc1 (b2019052016)
Java: Azul Systems, Inc. 11.0.3
I d’on’t understand what’s going wrong when I create instance ?
UDT definition
udt_TVG_ENE_A2401.json (21.6 KB)
Instance
eqt_TVG_ENE_A2401.json (7.3 KB)
Seem to be due to mispelling property enaum value, causing None value...
@paul-griffith, In the designer, I have the following error :
Error touching client id lock file.
java.io.FileNotFoundException: C:\Users\lionel\.ignition\cache\gw10.1.3.12_8088\clients.lck (Le chemin d�acc�s sp�cifi� est introuvable)
	at java.base/java.io.RandomAccessFile.open0(Native Method)
	at java.base/java.io.RandomAccessFile.open(Unknown Source)
	at java.base/java.io.RandomAccessFile.<init>(Unknown Source)
	at com.inductiveautomation.ignition.client.launch.steps.CacheStep$IDKeepalive.run(CacheStep.java:241)
and
09:00:41.022 [ClientProgressManager-1] ERROR com.inductiveautomation.ignition.designer.tags.tree.action.ImportTagAction$TagImportTask - null
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task 'b0afca41-e15d-4ec2-923c-023a80a86e10'
	at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
	at com.inductiveautomation.ignition.designer.tags.tree.action.ImportTagAction$TagImportTask.sendToGateway(ImportTagAction.java:184)
	at com.inductiveautomation.ignition.designer.tags.tree.action.ImportTagAction$TagImportTask.run(ImportTagAction.java:170)
	at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$ClientRunningTask.run(ClientProgressManager.java:510)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task 'b0afca41-e15d-4ec2-923c-023a80a86e10'
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:311)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:905)
	at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface$GatewayProviderProxy.importTagsAsync(GatewayTagInterface.java:533)
	at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.importTagsAsync(ClientTagManagerImpl.java:349)
	at com.inductiveautomation.ignition.designer.tags.tree.action.ImportTagAction$TagImportTask.sendToGateway(ImportTagAction.java:183)
	... 9 common frames omitted
Caused by: java.util.concurrent.TimeoutException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task 'b0afca41-e15d-4ec2-923c-023a80a86e10'
	at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$RunningTask.waitForResult(ClientProgressManager.java:452)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:295)
	... 14 common frames omitted
it seems that some “bad” expression for Ignition 8 take lot of time to be evaluated in the gateway when creating new tags.
We have a tag with an expression coming from 7.9, we need to adapt for 8.0,
but these “bad” expression take lot of time to be evaluated in the gateway
// Alarm Priority : Diagnostic(0), Low(1), Medium(2), High(3), Critical(4).
forceQuality(
 binEnc(
  //bit 0 : defautCom
  switch(tag(replace("[default]{PathToTag}","/TS/STATUS","/")+"{qualityPath}"+".Quality"),192,0,1),
  //bit 1 : alarmeInhibe
  {[.]../TC/INHIBER_ALARMES},
  //bit 2 :  synthèse alarme faible : Low(1)
  isAlarmActiveFiltered(replace("[default]{PathToTag}*","/TS/STATUS","/TA"), "", "", 1, 1, 0, 1, 0),
  //bit 3 : synthèse alarme moyenne : Medium(2)
  isAlarmActiveFiltered(replace("[default]{PathToTag}*","/TS/STATUS","/TA"), "", "", 2, 2, 0, 1, 0),
  //bit 4 : synthèse alarme majeure : High(3)
  isAlarmActiveFiltered(replace("[default]{PathToTag}*","/TS/STATUS","/TA"), "", "", 3, 3, 0, 1, 0),
  // bit 5 : desactive
  {[.]../TC/DESACTIVER_EQT},
  // bit 6 : mode local
  0,
  // bit 7 : mode manu
  0
 192
with tags.json logger set to DEBUG :
|provider|29May2019 09:17:49|Finished import in 3 minutes, 0 seconds|
|expr|29May2019 09:15:44|Error evaluating tag|
|expr|29May2019 09:15:43|Error evaluating tag|
|expr|29May2019 09:15:42|Error evaluating tag|
|expr|29May2019 09:15:41|Error evaluating tag|
|expr|29May2019 09:15:40|Error evaluating tag|
|expr|29May2019 09:15:39|Error evaluating tag|
|expr|29May2019 09:15:38|Error evaluating tag|
|expr|29May2019 09:15:37|Error evaluating tag|
|expr|29May2019 09:15:36|Error evaluating tag|
|expr|29May2019 09:15:35|Error evaluating tag|
|provider|29May2019 09:15:34|Starting read of 1 paths|
|expr|29May2019 09:15:34|Error evaluating tag|
|expr|29May2019 09:15:33|Error evaluating tag|
|expr|29May2019 09:15:32|Error evaluating tag|
|expr|29May2019 09:15:31|Error evaluating tag|
|expr|29May2019 09:15:30|Error evaluating tag|
|expr|29May2019 09:15:29|Error evaluating tag|
|expr|29May2019 09:15:28|Error evaluating tag|
com.inductiveautomation.ignition.common.expressions.ExpressionException: Error parsing/subscribing path '[default]{PathToTag}{qualityPath}.Quality' in tag() expression.
at com.inductiveautomation.ignition.common.expressions.functions.TagFunction.execute(TagFunction.java:111)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:66)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$SwitchFunction.execute(DefaultFunctionFactory.java:1231)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$BinaryEncFunction.execute(DefaultFunctionFactory.java:3157)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$ForceQualityFunction.execute(DefaultFunctionFactory.java:1340)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.expression.ExpressionTagActorFactory$ExpressionTagActor.runInternal(ExpressionTagActorFactory.java:154)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractExpressionActor.run(AbstractExpressionActor.java:120)
Caused by: java.io.IOException: com.google.common.collect.ComputationException: com.inductiveautomation.ignition.common.tags.paths.parser.TagPathFormatException: Illegal character '{' (Line 1 , Char 10)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser.parse(TagPathParser.java:154)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser.parse(TagPathParser.java:112)
at com.inductiveautomation.ignition.common.expressions.functions.TagFunction.execute(TagFunction.java:100)
... 15 common frames omitted
Caused by: com.google.common.collect.ComputationException: com.inductiveautomation.ignition.common.tags.paths.parser.TagPathFormatException: Illegal character '{' (Line 1 , Char 10)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser$ParseFunction.load(TagPathParser.java:355)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser$ParseFunction.load(TagPathParser.java:348)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3708)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2416)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2299)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2212)
at com.google.common.cache.LocalCache.get(LocalCache.java:4147)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4151)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:5140)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser.parse(TagPathParser.java:145)
... 17 common frames omitted
Caused by: com.inductiveautomation.ignition.common.tags.paths.parser.TagPathFormatException: Illegal character '{' (Line 1 , Char 10)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathLexer.errMsg(TagPathLexer.java:218)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathLexer.errMsg(TagPathLexer.java:222)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathLexer.yylex(TagPathLexer.java:731)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser._parse(TagPathParser.java:174)
at com.inductiveautomation.ignition.common.tags.paths.parser.TagPathParser$ParseFunction.load(TagPathParser.java:353)
... 26 common frames omitted
Moreover some bad expression in alarms fields seem to be very long to be evaluated.
I corrected the expression for Ignition 8, but I still have the issue.
UDT def :
udt_TVG_ENE_A2401.json (27.3 KB)
6 instances of this UDT :
eqt_TVG_ENE_A2401.json (9.3 KB)
The popup Executing Task / Configuring Running tags…
is displayed for more than 1 minute to create 6 instances…
the gateway is disconnected and re-connected.
tags.json logger = DEBUG.
I don’t have any message in the gateway logger.
is there any other logger to activate to troubleshoot this issue.
Hi @mazeyrat,
I talked with one of the developers and we think that this is the same underlying issue as the bug mentioned in your other post: [BUG-13990] Ignition 8.0.2-2019-05-09 - designer freeze when creating an UDT instance
I don’t have a ETA for that ticket, but it is high on our list. I will let you know when its fixed so you can see if that fixes this issue as well.
@mazeyrat, the mentioned ticket has been fixed in the latest build. Please let us know if you are still seeing this issue.
