Ignition 8.0.2 - build 2019-05-20
When I re-import an UDT with an xml file which has been exported from Ignition 8.0
(the udt has been deleted before and is not visible in the tag browser), I have the following error.
Tag errors occurred during tag import
Bad_Failure("Tag '_types_/test/TESTLMA2/vue2' already exists, and 'abort' collision policy has been specified")
Bad_Failure("Tag '_types_/test/TESTLMA2/numSSR' already exists, and 'abort' collision policy has been specified")
Bad_Failure("Tag '_types_/test/TESTLMA2/numQuai' already exists, and 'abort' collision policy has been specified")
Bad_Failure("Tag '_types_/test/TESTLMA2/numStation' already exists, and 'abort' collision policy has been specified")
Bad_Failure("Tag '_types_/test/TESTLMA2/TS/COND_INHIB_ALARMES' already exists, and 'abort' collision policy has been specified")
Bad_Failure("Tag '_types_/test/TESTLMA2/TS/STATUS' already exists, and 'abort' collision policy has been specified")
Moreover all the binding are wrong : a string like
{bindType=parameter, binding={myParameterName}} is displayed instead of {myParameterName}}
tags-TEST-V8-2.xml (15.2 KB)
