Create two tags in a folder, make on as memory tag with a fixed value, the other as an expression tag that references the memory tag, at this point it will all work fine, if the memory tag value adjusted it is immediately reflected in the expression tag, but if the name of the folder both tags reside in is changed the expression tag fails, the relative path does not seem to be updated.
I put in a ticket to address this. In the meantime, manually restarting the expression tag should re-establish the path to the memory tag.
Has this been fixed yet, I am running 8.0.3 and still seeing this behaviour, if not is there any way of restarting tags via scripting?
