[Bug-14291] Instances within Flex Repeaters no longer honor useDefaultViewWidth
I downloaded the latest build as of 6/25/19 and FlexRepeater received a few new properties. The issue is that after I can’t seem to allign instances to the left. They always expand across.
The border should wrap around the pump themselves and not expand all the way across. Also the instances should be left aligned.
To me this seems like a glitch introduced in the nightly build.
The issue describes here seems to stem from the fact that FlexRepeater.props.useDefaultViewWidth has stopped functioning as intended. I’ve opened an internal ticket.
This issue was fixed in the 8.0.3 nightly build that was uploaded today (7/18).
The nightly link still downloads from the 15th.
Yep - there’s an issue on our end. We’ll get the links updated to point to the correct nightly build and post about it.
Links now correctly point to 8.0.4 snapshot/nightly.
@paul-griffith
Looks like this bug is bag in the latest 8.0.4 nightly.
Hi @jpark,
Do you have a view/example that you can post that exhibits this bug?
Thanks,
Alen
Sorry please ignore this. The flex repeater is working fine.
Something changed between the nightlys where my embedded view is no longer expanding properly. I’m still trying to determine what was changed.
