In 8.04 nightly, embedded views in coordinate containers no longer scale contents based on the size of the embed box. Irrespective of “useDefaultViewWidth”. I re-installed 8.03 and this started working properly again.
Can you provide more information on your setup. Thanks!
-Yousuf
Never mind. I see what is going on. As a temporary fix, you can set the root style property of your embedded views to flex 0 0 auto. Try that.
-Yousuf
This issue should be fixed in the latest nightly build. If you are still seeing this issue, please let us know.
