I have an array of two objects as parameters of a view. I’m using this through an embedded view.
Every time I type a character here, the cursor moves to the “Perspective Property Editor” in filter’s bar. Using Ignition 8.02.
"Here" is not clear in this context.
I've tried to replicate this issue in two places: the params of an embedded View's properties, and the params of a View, but neither has resulted in a replication of your issue. The only place Ive been able to replicate something similar is while adding new properties to the Style object, which is a result of focus being sent to the Property Editor when the new key is inserted. I'll open a ticket for that issue, but I'd also appreciate some clarification regarding where exactly you are clicking in the Designer.
