[bug-14612]system.tag.getConfiguration fails on memory dataset tag if dataset is defined
In script console on version 8.02:
print system.tag.getConfiguration('[default]New Tag')
Gives this result as expected for a new memory tag of type dataset that doesn’t yet have any data (not even defined columns):
[{u'dataType': DataSet, u'path': [default]New Tag, u'tagType': AtomicTag, u'name': u'New Tag', u'valueSource': u'memory'}]
However, as soon as the dataset value exists (even just one column defined with no rows), it fails with this error:
Java Traceback:
  File "<buffer>", line 1, in <module>
java.lang.IllegalArgumentException: Cannot create PyString with non-byte value
	at org.python.core.PyString.<init>(PyString.java:57)
	at org.python.core.PyString.<init>(PyString.java:70)
	at org.python.core.PyString.<init>(PyString.java:74)
	at org.python.core.PyObject.__repr__(PyObject.java:238)
	at org.python.core.PyList.list_toString(PyList.java:512)
	at org.python.core.PyList.toString(PyList.java:498)
	at org.python.core.PyObject.__str__(PyObject.java:271)
	at org.python.core.StdoutWrapper.printToFile(StdoutWrapper.java:108)
	at org.python.core.StdoutWrapper.print(StdoutWrapper.java:186)
	at org.python.core.StdoutWrapper.println(StdoutWrapper.java:272)
	at org.python.core.Py.println(Py.java:1858)
	at org.python.pycode._pyx755.f$0(<buffer>:1)
	at org.python.pycode._pyx755.call_function(<buffer>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at org.python.core.Py.exec(Py.java:1658)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
	at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:116)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:506)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:494)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: Cannot create PyString with non-byte value
	at org.python.core.Py.JavaError(Py.java:552)
	at org.python.core.PyTableCode.call(PyTableCode.java:180)
Caused by: java.lang.IllegalArgumentException: Cannot create PyString with non-byte value
	... 14 more
This looks like the same root cause as a bug I ran into about a week ago. I have a patch up against our internal Jython build, which will then make it into another build - possibly 8.0.4, but it may slip to 8.0.5 at this point.
The fix for this made it into 8.0.6 - that’s what I get for trying to estimate a timeline :slight_smile:
