[BUG-14729]: UDT Parameter Binding with number formatting
I searched but didn’t find this already reported.
When setting a tag’s OPC Item Path in a UDT to use a number formatted parameter like:
ns=2;s=[default]PARK/WEC{PARAM_TURBINEID|#00}/_diagnostics_/Is Connected
the parameter doesn’t get zero padded:
ns=2;s=[default]PARK/WEC1/_diagnostics_/Is Connected
Thanks.
What build/nightly version is this?
This is using 8.0.3 (b2019071202).
Hi @malone46844,
I’ve been able to reproduce this bug in 8.0.3. Seems like number formatting doesn’t work for constant parameter expressions such as your case. As a workaround, you can try doing adding a trivial operation to the constant expression, such as PARAM_TURBINE_ID + 0. I’ve attached the ticket number to this post to keep track of its progress.
Thanks,
Alen
{Param + 0|00} worked like a charm. Thank you much for the workaround.
Man thanks for posting that, that trick helped me out!
Hey guys, this is still a bug and +0 didn't work for me. Any update on this? Cheers.
Ignition 8.1.25
