[Bug-1476]Translations Button with Image
It seems there is an issue with the translations where a button with an image will not translate the button text however if the image is removed the same text will then translate.
The first image is with Perspective set to Spanish with the image enabled. The second image is with the application still set to Spanish but the images were removed from the button components.
We are on 8.1.1 of Perspective.
You’re absolutely right. I’ll open a ticket for this right now.
Any update on this bug?
It should have been fixed as part of 8.1.5.
ah i was still on 8.1.4 thx
