Hi all,
I encountered a strange error that did not initially appear on a script, but appeared after a few saves. So, the script was working until the error occurred. The script was a transform script on the props.data property of a table that colored the text/background of certain rows/cells as needed. The error seems to be coming from a reference to the session custom properties, and even points to a url in the jython documentation indicating it is a jython error. However, it appears to have been fixed in 2018, so i’m not sure if perspective is using an outdated version or what.
Here is the link given in the error:
https://bugs.jython.org/issue2487
And here is a snapshot of the error:
Did I just do something wrong or is this a real problem?
We’re using 8.0.4 Ignition.
Best,
Roger
