does anybody hit or reproduce this bug in 8.0.4-Nightly ???
@mgross, @paul-griffith, I suppose it is relative to DateTime datatype in the Tag managed Provider ?
In the script console, if I test a write, I have an error too :
import system
path = "[replay]CommandTags/startDate"
now = system.date.now()
system.tag.writeBlocking([path],[now])
return
[Bad]
In the module that create the Managed Tag provider with the tag :
this.ourProvider.configureTag(STATUS_TAG_START_DATE, DataType.DateTime);
MyWriteHandler myWriteHandler = new MyWriteHandler();
this.ourProvider.registerWriteHandler(COMMAND_TAG_START_DATE, myWriteHandler);
protected class MyWriteHandler implements WriteHandler {
@Override
public synchronized QualityCode write(TagPath target, Object value) {
try {
if (tagPath.equalsIgnoreCase(COMMAND_TAG_START_DATE)) {
updateValue(COMMAND_TAG_START_DATE, value);
startDate = (Date) value;
return QualityCode.Good;
} catch (Exception e) {
logger.error("WriteHandler() - Exception : ", e);
return QualityCode.Bad;
The module works in 7.9 but in 8.0.4, DateTime exposed doesn’t works !
in the gateway, the error :
ReplayProvider 28Aug2019 08:59:02 WriteHandler() - Exception :
java.lang.IllegalArgumentException: Nesting qualified values.
at com.inductiveautomation.ignition.common.model.values.BasicQualifiedValue.(BasicQualifiedValue.java:58)
at com.inductiveautomation.ignition.gateway.tags.managed.ManagedTagProviderImpl.updateValue(ManagedTagProviderImpl.java:251)
at com.inductiveautomation.ignition.gateway.tags.managed.ManagedTagProvider.updateValue(ManagedTagProvider.java:25)
at com.bouyguesenergiesservices.ignition.gateway.replay.tag.ReplayProvider$MyWriteHandler.write(ReplayProvider.java:923)
at com.inductiveautomation.ignition.gateway.tags.managed.ManagedTagProviderImpl$ManagedProviderValueActorFactory$ManagedProviderValueActor.processWrite(ManagedTagProviderImpl.java:450)
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.write(ExecutableTag.java:343)
at com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.writeAsync(TagProviderImpl.java:539)
at com.inductiveautomation.ignition.gateway.tags.provider.RestrictedTagProvider.writeAsync(RestrictedTagProvider.java:61)
at com.inductiveautomation.ignition.gateway.tags.model.impl.GatewayTagManagerImpl.lambda$writeAsync$12(GatewayTagManagerImpl.java:628)
at com.inductiveautomation.ignition.gateway.util.GroupMapCollate.lambda$groupMapCollateIndexed$5(GroupMapCollate.java:53)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.HashMap$EntrySpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.ignition.common.util.Futures.sequence(Futures.java:26)
at com.inductiveautomation.ignition.gateway.util.GroupMapCollate.groupMapCollateIndexed(GroupMapCollate.java:62)
at com.inductiveautomation.ignition.gateway.tags.model.impl.GatewayTagManagerImpl.writeAsync(GatewayTagManagerImpl.java:612)
at com.inductiveautomation.ignition.gateway.tags.model.ProjectDefaultTagManagerFacade.writeAsync(ProjectDefaultTagManagerFacade.java:270)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.TagProviderRpc.write(TagProviderRpc.java:132)
at jdk.internal.reflect.GeneratedMethodAccessor211.invoke(Unknown Source)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:225)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:409)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
It seem I have the issue for all the tags,
the value seem to be a Qualified value in 8.0 instead of simple value like in 7.9
The following Interface WriteHandler is still ok ?
com.inductiveautomation.ignition.gateway.tags.managed.write(TagPath target, java.lang.Object value)
ReplayProvider 28Aug2019 09:06:11 WriteHandler() - Exception :
java.lang.ClassCastException: Cannot coerce value '[3.0, Good, Wed Aug 28 09:06:11 CEST 2019 (1566975971350)]' into type: class java.lang.Double
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1339)
at com.inductiveautomation.ignition.common.TypeUtilities.toDouble(TypeUtilities.java:1447)
at com.bouyguesenergiesservices.ignition.gateway.replay.tag.ReplayProvider$3.write(ReplayProvider.java:1168)
