I have a UDT structure that has custom properties defined. I then use these properties inside the tag fields such as OPC Server and OPC Item Path, etc. For example, the OPC Item Path is defined as [{Device}]C{DI_Address+1}. When I copy the tag, then paste it into the same structure, all fields that have a path related to a property are lost. Regular text still seems to be preserved in fields without a referenced property. I have last night’s build and have confirmed that this feature works on 8.03 stable.
Thanks-
Are you still seeing this issue in the latest nightly? When I attempt to duplicate this issue in the latest 8.0.5 nightly, I am not running into the issue you are describing. A couple of things I would like to confirm:
- When you say “custom properties” are you referring to parameters within the main UDT definition like: or do you mean properties added to UDT members like: I did check both, but I just want to confirm we are talking about the same thing.
- When copying values, are you referring to copying existing UDT instances, or members within UDT Definitions?
If this is still an issue I want to ensure it does get resolved.
Thanks,
Garth
Hi Garth-
See attached screenshots. I am copying a tag within a UDT. The original tag “ALARM” has custom properties defined for OPC Server, OPC Item Path, Tooltip, and Documentation. Such as: {Server}, {Description}, etc. When I copy the “ALARM” tag and paste it in the same UDT to create “ALARM 1”, the fields with the custom properties are now blank. See screen shots. I have 8.04 nightly build 2019082602.
Thanks-
Thanks for the clarification. I am able to duplicate the issue and have created an issue to resolve it.
Garth
Thanks for reporting this, we’ll get it fixed before 8.0.4 final.
