I recently noticed that when syncing tags that have square brackets in them (via the SDK), Ignition creates a folder.
EXAMPLE
Tag[1]_Test
Tag[1]_MoreTest
Tag[2]_Other
Tag[2]_Example
will create a folder named “Tag[1]” with “_Test” and “_MoreTest” as children tags, and folder “Tag[2]” with “_Other” and “_Example” as children tags.
Since Ignition does not officially support square brackets in tag names, is that an intended functionality? Will this be coming to Ignition as a feature, or is this just a glitch? What is the meaning of square brackets in Ignition?
Thank you,
Alex
