[bug-1498]Perspective module loads and runs on 8.1.0 but fails to run on 8.1.1
I have a module that builds, loads and runs on 8.1.0.
However, the same module will not start on 8.1.1
ext.sdk_version = “8.1.0”
requiredIgnitionVersion “8.1.0”
requiredFrameworkVersion “8”
I have tried changing requiredIgnitionVersion to 8.1.1
it still fails to load.
any ideas on what I can do to fix this?
Caused by: java.util.MissingFormatArgumentException: Format specifier '%s'
	at java.base/java.util.Formatter.format(Unknown Source)
	at com.inductiveautomation.ignition.common.util.LoggerEx.createMessage(LoggerEx.java:187)
	at com.inductiveautomation.ignition.common.util.LoggerEx.warnf(LoggerEx.java:287)
	at com.inductiveautomation.perspective.common.api.ComponentRegistry.registerComponent(ComponentRegistry.java:83)
	at com.faker.gateway.fakeName.startup(fakeName.java:38)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2433)
	... 16 more
So, the good news: The exception being thrown isn’t your fault, it’s a logger message from our end that’s malformed (whoops). The message that it’s failing to log is indicating that you’re trying to register a component ID that was already registered:
        if (componentRegistry.get(comp.id()) != null) {
            log.warnf(
                "Component '%s' already registered. Registration will proceed and overwrite existing definition."
Do you have two modules built from the samples installed? Have you changed your component IDs from the defaults in the module?
Its a single module.
I haven’t changed anything.
the module builds successfully
I have 8.1.0 on server A
module installs and loads and works
I have 8.1.1 on server B
module installs however fails to load/ start.
Well, I can guarantee that the issue is that two components are attempting to load with the same ID. Have you restarted your gateway?
To trouble shoot I downloaded the trial versions of both 8.1.0 and 8.1.1 and installed them other older computers. Installed only the default modules and the one I am working on. The issue still persists
@paul-griffith How does one resolve the issue that two components have the same ID?
You’ll need to change the code so that each component you’re attempting to load has a unique ID - notice how each component in our module example has a distinct ID:
I double checked all my component_ID names. none are the same. If that were the issue, wouldn’t the module fail to load on 8.1.0?
I may have explained it wrong
Sever A has 8.1.0
Server B has 8.1.1
the module will run correctly on Server A
the same module fails to load on Server B
Can you PM me the module, built or source?
I should be able to. Let me get clearance from my boss.
