Hello all,
I am trying to add users and roles in ignition gateway however I keep getting errors. When I try to add a user I get the error message “Transaction already committed, need begin.”. I have tried reinstalling ignition, adding a different user source, resorting a different gateway backup. Had this problem in version 8.0.15 so I upgraded to version 8.0.16 but still having the issue.
Did you have a look in the log at the error it produced?
This is what is in the logs for “Transaction already committed, need begin”:
simpleorm.utils.SException$Error: Transaction already committed, need begin.
at simpleorm.sessionjdbc.SSessionJdbc.checkBegunThread(SSessionJdbc.java:353)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:437)
at simpleorm.sessionjdbc.SSessionJdbc.commit(SSessionJdbc.java:375)
at com.inductiveautomation.ignition.gateway.authentication.impl.InternalUserSource.addUser(InternalUserSource.java:639)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.addUser(UserSourceWrapper.java:339)
at com.inductiveautomation.ignition.gateway.web.components.user.UserSourceEditPage.onUserAdded(UserSourceEditPage.java:100)
at com.inductiveautomation.ignition.gateway.web.components.user.UserSourceEditPage$UserActionTable$11.onUserEdited(UserSourceEditPage.java:366)
at com.inductiveautomation.ignition.gateway.web.components.user.UserEditForm.onSubmit(UserEditForm.java:544)
at com.inductiveautomation.ignition.gateway.web.components.user.UserEditForm$1.onSubmitInternal(UserEditForm.java:155)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:67)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1248)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1242)
at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274)
at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1241)
at org.apache.wicket.markup.html.form.Form.process(Form.java:923)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:769)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:702)
at jdk.internal.reflect.GeneratedMethodAccessor85.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:240)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:226)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1596)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:545)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
and “Attempting to open new session, but session already open for this thread.”
java.lang.Exception: null
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:56)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:44)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.queryOne(PersistenceInterfaceImpl.java:152)
at com.inductiveautomation.ignition.gateway.audit.AuditManagerImpl.getId(AuditManagerImpl.java:121)
at com.inductiveautomation.ignition.gateway.audit.AuditManagerImpl.getProfile(AuditManagerImpl.java:136)
at com.inductiveautomation.ignition.gateway.audit.AuditManagerImpl.getGatewayAuditProfile(AuditManagerImpl.java:179)
at com.inductiveautomation.ignition.gateway.authentication.impl.InternalUserSource.auditUserAction(InternalUserSource.java:814)
at com.inductiveautomation.ignition.gateway.authentication.impl.InternalUserSource.addUser(InternalUserSource.java:638)
Sorry for the late response. A similar issue has been reported internally and the issue was that the Gateway Audit Profile within Config > Gateway Settings was set to an Audit profile that does not exist any longer. Is that the case with your gateway?
Yes this was the issue. Thanks!
