[Bug-16797] Ignition Gateway Start on Linux on boot
This depends on your version of Ubuntu, but for most recent versions, you can use the systemctl command (as root).
These are pretty simple commands:
systemctl status ignition – Check the status
systemctl start ignition – Start it now
systemctl stop ignition – Stop it now
systemctl enable ignition – Autostart on boot
systemctl disable ignition – Remove the autostart symlinks
Older versions of Ubuntu generally use init scripts.
