I have a script that takes in a csv with TagPath and then columns of the names of UDT parameters to set using system.tag.configure, however when I use it, the parameters are added as expected but the UDT tagType is converted to an AtomicTag where before the configure it was a UdtInstance.
As a single example, this is what I’m passing as the “tags” array into the configure function:
tag = {'name': '01', 'parameters': {'Description': {'dataType': 'String', 'value': 'Pump Station 1'}, 'Alarm_ParentPath': {'dataType': 'String', 'value': 'Hellow'}, 'Alarm_Area': {'dataType': 'String', 'value': 'Wine Delivery'}}}
system.tag.configure(basePath = tagParentPath, tags = [tag], collisionPolicy = 'm')
