[BUG-2855]Touchscreen and text field vs numeric input field keyboard usage inconsistant?
Using Ignition 8.1.0.
I am working on a project where the client has touchscreen enabled and a keyboard, so clicking on any text field brings a keyboard to the screen that they can use to type, or they use the actual keyboard without issue.
I recently made a numeric text field and when clicked the 0-9 keypad comes up, but using the keyboard and typing in numbers does not do anything.
I looked at the behavior settings and they seem to match as much as possible so I am not sure if this is intended behavior or if I am missing something or if perhaps this was fixed in a later version.
Text Field:
Numeric Field:
This is just a bug with the numeric keypad dialog, unfortunately.
