[BUG-5529] Imported component palettes not showing
Version 8.1.9, but probably happened sooner. :wink:
I can import a custom palette, but it doesn’t show in the designer. If I import again, is asks if I want to overwrite. So, it appears the the import somewhat works.
Same problem here 8.1.21
When I import into a complete new project it works. But not an existing one.
Still a problem in 8.1.22.
It does not display in the export either. ExportedFile.zip --> com.inductiveautomation.vision is missing custom-palettes subfolder.
There might be a workaround. Import the project that contains a custom palette and make it inheritable. Then, set your existing project to inherit from it.
