[Bug-657] - Error when copy/pasting a cell update binding
Ignition version 8.0.13.
Just calling attention to an apparent bug in Vision. When copy/pasting a dataset binding that uses a cell update binding, i’ll get the following error on paste:
Error during retrieval of clipboard data.
java.io.NotSerializableException: com.inductiveautomation.factorypmi.application.binding.interchange.CellUpdateBindingConfig$Spec
	at java.base/java.io.ObjectOutputStream.writeObject0(Unknown Source)
	at java.base/java.io.ObjectOutputStream.writeObject(Unknown Source)
	at java.base/java.util.ArrayList.writeObject(Unknown Source)
	at java.base/jdk.internal.reflect.GeneratedMethodAccessor2079.invoke(Unknown Source)
	at java.base/java.io.ObjectStreamClass.invokeWriteObject(Unknown Source)
	at java.base/java.io.ObjectOutputStream.writeSerialData(Unknown Source)
	at java.base/java.io.ObjectOutputStream.writeOrdinaryObject(Unknown Source)
	at java.base/java.io.ObjectOutputStream.defaultWriteFields(Unknown Source)
	at java.desktop/sun.awt.datatransfer.TransferableProxy.getTransferData(Unknown Source)
	at com.inductiveautomation.ignition.client.util.ClipboardUtil.doPasteTransferableFromClipboard(ClipboardUtil.java:49)
	at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel$6.actionPerformed(PropertyTablePanel.java:281)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.0.13 (b2020060815)
Java: Azul Systems, Inc. 11.0.6
I’ve tested this on a few datasets, seems to be easily reproducible on any dataset, down to 1x1. Any type of cell update (e.g. static value) seems to cause it.
In case this takes a while to fix, the simplest workaround is to manually copy/paste the binding configuration from the editor. See the screenshot below.
Thanks for the clear, concise report. This should be a relatively easy fix in our code, but because it’s fairly niche (and there’s a workaround) it’ll probably take a while to get fixed.
