I am experiencing a bug in 8.0.13 where the binding and tag change scripts on a UDT definition does not appear in the designer.
See below:
If you export the UDT, all the required info is in the JSON, as seen in the snippet of the export below:
"opcItemPath": {
"bindType": "parameter",
"binding": "ns\u003d3;s\u003d\"{InstanceName}\".\"Cfg\".\"AnalogueInputDeviceID\""
"opcServer": {
"binding": "{PLC}"
"valueSource": "opc",
"eventScripts": [
"eventid": "valueChanged",
"script": "Script is here, but redacted"
"documentation": "Unique device ID",
"name": "AnalogueInputDeviceID",
"tagGroup": "LeasedSlow",
"tagType": "AtomicTag"
I can fix the problem by importing the JSON and overwriting the UDT, but it the problem reappears at some later stage.
See the UDT after the overwrite import:
Please advise if there is any more info I can provide.
Regards,
Deon
