[BUG] 8.0.3-nightly - contextual menu in project browser
@awalker
A minor issue…
When you select a project ressource in the project browser, the line is blue highlighted.
A right mouse click show the contextual menu, only if yoo click on the text.
If you click on the end of the line, no menu is displayed.
Hi Lionel,
You are correct that the contextual menu only shows when you right click on the text label. This is a limitation of how trees render each item in Java. There might be a solution to extend the area of the line, but seems hacky and might lead to visually undesirable results.
Thanks,
Alen
