If you pass an object to an embedded View, these params can’t be used in the EV; they just use the default values there at save.
I have this View which I embed onto a page:
"custom": {
"bitAvail": false,
"btnAvail": true,
"itemSelected": "BrowseValue [value\u003dnull, info\u003dnull, configVersion\u003d9]"
"params": {
"availType": "table",
"bitAvail": {
"bit": "",
"integerAvailTagPath": ""
"optionLabel": "FS4157",
"optionValue": 4157,
"selectTagPath": "",
"tableAvail": {
"avail": true
"propConfig": {
"custom.bitAvail": {
"binding": {
"config": {
"fallbackDelay": 2.5,
"mode": "indirect",
"references": {
"1": "{view.params.bitAvail.integerAvailTagPath}"
"tagPath": "{1}"
"transforms": [
"expression": "try(getBit({value}, {view.params.bitAvail.bit}), false)",
"type": "expression"
"type": "tag"
"persistent": true
"custom.btnAvail": {
"binding": {
"config": {
"expression": "if({view.params.availType} \u003d \u0027bit\u0027\r\n\t,{view.custom.bitAvail}\r\n\t,{view.params.tableAvail.avail}\r\n)"
"type": "expr"
"persistent": true
"custom.itemSelected": {
"binding": {
"config": {
"bidirectional": true,
"mode": "indirect",
"references": {
"1": "{view.params.selectTagPath}"
"tagPath": "{1}"
"type": "tag"
"persistent": true
"custom.thisItemSelected": {
"binding": {
"config": {
"mode": "indirect",
"references": {
"tagPath": "{1}"
"transforms": [
"expression": "{value} \u003d {view.params.optionValue}",
"type": "tag"
"params.availType": {
"paramDirection": "input",
"persistent": true
"params.optionLabel": {
"persistent": true
"params.optionValue": {
"persistent": true
"params.selectTagPath": {
"persistent": true
"props": {
"defaultSize": {
"height": 40,
"width": 100
"root": {
"children": [
"events": {
"dom": {
"onClick": {
"config": {
"script": "\tself.view.custom.itemSelected \u003d self.view.params.optionValue\n\tsystem.perspective.closePopup(\u0027options-popup\u0027)"
"scope": "G",
"type": "script"
"meta": {
"name": "Button"
"position": {
"basis": "34px",
"grow": 1
"propConfig": {
"props.enabled": {
"binding": {
"config": {
"path": "view.custom.btnAvail"
"type": "property"
"props.style.classes": {
"binding": {
"config": {
"path": "view.custom.thisItemSelected"
"transforms": [
"fallback": "",
"inputType": "scalar",
"mappings": [
"input": false,
"output": "Buttons/Body Buttons/Text"
"input": true,
"output": "Buttons/Body Buttons/Text UIElement/MenuSelected"
"outputType": "style-list",
"type": "map"
"type": "property"
"props.text": {
"binding": {
"config": {
"path": "view.params.optionLabel"
"type": "property"
"props": {
"style": {}
"type": "ia.input.button"
"meta": {
"name": "Icon"
"position": {
"basis": "18px",
"shrink": 0
"propConfig": {
"position.display": {
"binding": {
"config": {
"path": "view.params.tableAvail.avail"
"type": "property"
"props": {
"path": "material/insert_emoticon"
"type": "ia.display.icon"
"meta": {
"name": "root"
"props": {
"direction": "column"
"type": "ia.container.flex"
Params:
The smiley face’s postion.display is bound to the last param in the screenshot (tableAvail.avail), a boolean. If I embed this onto a page and toggle the tableAvail prop, nothing happens. If it do the same in the View itself, it works
It works when I don’t use objects. God damn, spent a day and a half chasing my tail…
"custom": {
"bitAvail": false,
"btnAvail": "",
"params": {
"bitAvail": {
"bit": "",
"bitAvail_bit": "",
"bitAvail_integerAvailTagPath": "",
"tableAvail": {
"avail": true
"tableAvail_avail": ""
"propConfig": {
"binding": {
"config": {
"mode": "indirect",
"references": {
"1": "{view.params.bitAvail_integerAvailTagPath}"
"tagPath": "{1}"
"transforms": [
"expression": "try(getBit({value}, {view.params.bitAvail_bit}), false)",
"type": "tag"
"persistent": true
"binding": {
"config": {
"expression": "if({view.params.availType} \u003d \u0027bit\u0027\r\n\t,{view.custom.bitAvail}\r\n\t,{view.params.tableAvail_avail}\r\n)"
"type": "expr"
"persistent": true
"binding": {
"config": {
"mode": "indirect",
"references": {
"tagPath": "{1}"
"type": "tag"
"persistent": true
"binding": {
"config": {
"mode": "indirect",
"references": {
"tagPath": "{1}"
"transforms": [
"type": "tag"
"persistent": true
"params.bitAvail_bit": {
"persistent": true
"params.bitAvail_integerAvailTagPath": {
"persistent": true
"persistent": true
"persistent": true
"persistent": true
"params.tableAvail_avail": {
"persistent": true
"props": {
"defaultSize": {
"height": 40,
"width": 100
"root": {
"children": [
"events": {
"dom": {
"onClick": {
"config": {
"scope": "G",
"type": "script"
"meta": {
"name": "Button"
"position": {
"basis": "34px",
"grow": 1
"propConfig": {
"props.enabled": {
"binding": {
"config": {
"type": "property"
"binding": {
"config": {
"transforms": [
"fallback": "",
"mappings": [
"input": false,
"input": true,
"type": "map"
"type": "property"
"props.text": {
"binding": {
"config": {
"type": "property"
"props": {
"style": {}
"meta": {
"name": "Icon"
"position": {
"basis": "18px",
"shrink": 0
"propConfig": {
"binding": {
"config": {
"type": "property"
"props": {
"meta": {
"name": "Icon_0"
"position": {
"basis": "18px",
"shrink": 0
"propConfig": {
"binding": {
"config": {
"type": "property"
"props": {
"color": "#FA0000",
"meta": {
"name": "root"
"props": {
I stopped using the objects and used the bottom 3 properties instead and my sanity was regained
