[BUG ?] ActivityLevel Tag does not uptade after automatic failback
Version 8.1.28
I have two redundant gateways GW1 (master) and GW2 (backup)
In normal mode the activity levels of the gateways are :
  • GW1 active
  • GW2 warm
If I simulate a loss of connection between the gateways, then the activity levels of the gateways are :
  • GW1 active
  • GW2 active
    Which is normal.
Then, when the connection between the two gateways comes back, the activity levels of the gateways are :
  • GW1 active
  • GW2 warm
    Which is normal.
The problem is that the AtivityLevel tag ([System]/Gateway/Redundancy/ActivityLevel) of GW2 is not updated. Its value stays at "active" instead of "warm"
Sounds like a bug you should report. (This forum is not official support. Open a ticket through IA's support site.)
